I spent the last few late evenings when I should have gone to bed trying to work this out.
I’m trying to retrieve the tag name of a selected object.
I’ve checked out ruby.sketchup and done many Forum / Google searches…
Tag
is still called as Layer
in Ruby API…
References:
#Dirty code snippet:
def get_tag_name
model = Sketchup.active_model
selection = model.selection
if selection.single_object?
if selection.first.respond_to?(:layer)
object = selection.first
layer = object.layer
layer_name = Sketchup.version.to_i < 20 ? layer.name : layer.display_name
UI.messagebox("#{layer_name} is associated to selected object #{object.class} ")
else
UI.messagebox("Selected object has no Layer/Tag name .")
end
else
UI.messagebox("Select exactly one object")
end
layer_name
end
get_tag_name
EDIT: #display_name
added for SU version > 2020
thanks dezmo
correct me if I’m wrong, essentially…
layer_name = layer.name
is retrieving the tag name which was what I have been trying to work with but just couldn’t get it right.
Yes.
As you can see in my previous post as well… but here are the proof:
As of SketchUp 2020 “Layers” were renamed to “Tags” in the UI. The API retains the use of “Layer” for compatibility and is synonymous with “Tag”.
https://ruby.sketchup.com/Sketchup/Layer.html
BTW. Again, for compatibility reason, they implemented a method In SU2020:
The #display_name method is used to retrieve the display name of the layer.
(implemented to my first response)
was using the layer class but trying to get something out of layer.name was eluding me
Actually a one liner:
Sketchup.active_model.selection.first.layer.name
But This will return “Layer0
” for “Untagged
” in SU 2020 or later
Therefore:
# if you are using SU 2020 or later
Sketchup.active_model.selection.first.layer.display_name
Will give you the proper name as in the UI. But you will get an error in earlier SU versions.
