Is there a way to have some extentions turned off by default? I have a extension which i use to render but, it’s starts up by default which takes up a minute or so, which is verry enoying especially when switching al lot between sketchup files.
I tried the search (also google) but, i can’t find the answer.
There are several ways, two are
Use the Extension manager to disable the relevant extension
or
Install the Sketchucation tool which allows you to turn extensions on and off
This sounds like a malfunctioning extension. No extension should take minutes to do anything unless you tell it to do something. I’d contact the extension authors.
Option one works but, this is simply always on or always off i was hoping for an option where it’s off by default so even if i had turned it on it will be off next time.
Thanks for your reply man!
Not exactly what im looking for, i’m looking for a kind of toggle i guess which kan turn on the extention only once and wiil be off next time…
I’ve installed several render extensions to test them. They have all noticeably extended SketchUp’s startup cycle. Not minutes, but certainly in the range of 20 … 30 seconds.
