Transparency issue in Unexploded sketchup models
Hi,
I tried to access the material info of an unexploded sketchup model using C sdk, it doesn’t give any opacity values.
I exploded the model and then i could see opacity values and transparency.
I am using this api to get opacity values
SUMaterialGetOpacity(Material_m, &MaterialOpacity);
Any idea what’s the issue?
It’s hard to tell without seeing the skp file…
From what I understand, to get Opacity values of a material, you first need to check if an Opacity value has been set:
SU_RESULT SUMaterialGetUseOpacity ( SUMaterialRef material, bool * use_opacity)
http://extensions.sketchup.com/developer_center/sketchup_c_api/sketchup/material_8h.html#a5ec103e21860b9646b06cb0e4f310349
But I am guessing that is not your problem?
Issue is fixed. I was not using the opacity values properly.
Anyways, I used SUMaterialGetOpacity.
