Hello,
On a model, I have SUTextureGetFileName that returned “sits:blinn1SG.png”.
What does sits: means? Please someone could explain this?
Thanks,
Manuel
Hello,
Thanks,
Manuel
That’s not something SketchUp adds. I’m surprised a colon has managed to sneak itself into a filename field though…
Thanks Thomas! I This is the first time I have come across this case! It reassures me. SUTextureSetFileName should not check too much the providen filename.
What was the actual full texture path ?
Are you running in a virtualized environment ?
Hello Dan,
I have no idea, this is a customer file and I don’t know anything of its working context.
Manuel
If you open the file in SketchUp the Ruby API will return the full path. See:
Also are you aware of bugs in older version of the SDK ?
Do you have a way to dump all the material textures of a file in ruby, so I can check right now.
I don’t remember the name of the materials and there is a lot in this model.
I have no access to the computer with the c++ code.
Thanks.
model = Sketchup.active_model
matls = model.materials
matls.each do |matl|
puts "Material name: #{matl.name}"
if matl.texture
puts " Texture path: #{matl.texture.filename}"
else
puts " Untextured"
end
end
Note that “native” materials distributed by SketchUp do not show the path, just the filename.
Thanks!
The filename is the following:
Material name: sits_blinn1SG1
Material path: C:\Users\Lena\AppData\Local\Temp\3de42E2D5C6\sits:blinn1SG.png
It is not a valid filename. I guess that Sketchup should refuse it.
What SketchUp version was it made with ?
According to the file it should be 18.0.16975
Aside: I should have had the above snippet use the caption “Texture Path:” (fixed.)
It certainly is weird. Because it is from the User’s local Temp folder, I would think that this was a result of a GUI command rather than the user browsing to an image file and manually selecting it.
It might have been a texture that came in attached to a component’s material that was inserted into the model. The filename almost looks like something from Linux. (Ie, the 4 character device name.)
SketchUp should not store invalid path strings in any of it’s properties for any of it’s objects.
We have filed complaints about this in the recently.
