Ok, here is a pic and the file of a part i am modeling. I need a 19mm radius circle to be tangent on the angled line, but not tangent to the point it connects to. How the heck do i do that? thanks
thanks
tangent arcs.skp (19.5 KB)
thanks
Start Arc Tool, hoover over the first line (or segment of circle/curve), click.
start looking over the other line and click when it turns magenta
The curve turns black, hoover back on the line untill it is Magenta, again.
Type the radius you want.
hit Enter
Here is your original request:
And then after you edited the post:
The same order:
Start Arc tool, hoover over the first line, click
keep arc cyan while you are going to that point.
click on point, curve turns black, mouve mouse to have it turn cyan, again,
let go of the mouse and type the radius and hit enter.
Thank you very much. Now, on the second demo, is the arc tangent at both points or just on the angled line?
Not trying to be picky, my goal is to make it tangent at the line and NOT at the point. Only reason, i have to take the volume of this solid once extruded and find its mass based off of the density of 1020 steel. I have a 1% room for error according to the assignment haha.
thanks
just the line for the tangency:) and i am using 96 segments.
Ok, one small question, when i type 19, it accepts it but when i use the arc center point finder extension, it says that my radius is 13.xxx, and not 19.
Am i supposed to type in an r somewhere?
thanks again:)
EDIT: i have tried to use the move tool with no luck to get the cirlce tangent on the line and not at the point. i get extremly close, but off by about 3 mm
Select the arc then edit the radius in entity info.
WORD! that worked box. Thanks for that tip. didnt know i could do that in entity info
SIde note, whats the extension for a movable measure value box?
View->Toolbars-> tick the measurements bar
