That model contains a square face that contains the hole.
When I traverse the faces, I check SUFaceIsComplex to know if there is hole or not.
SUFaceIsComplex never return true to tell me that one of the face contains hole.
All the face are considered simple and as a result I get the mesh converted without the hole as shown below.
But! If I do the same operation using SUModelCreateFromFile and traverse the face with the same code, things go differently.
SUFaceIsComplex returns true for the square plane and the code that handle the face triangulation (that take care of the hole) is reached. As a result, I’ve got the mesh correctly converted as shown below:
So the question is why faces that come from SUModelFromExisting does not handle correctly holes whereas the one that came from SUModelCreateFromFile are correct.
This lead to modify the user model, which is usually not a good idea.
Is there a proper way to do that operation?
Most of the component group does not contains holes.
How can I know that a component/group explode operation is needed because it will lead to create the appropriate geometry?
I feel that this can be only done at the ruby level but I might be wrong.
Is the explode operation is undoable?
@DanRathbun I thought to such a solution, but this will result in a lack of performance as well as memory loss.
I also note that SUGroupExplode is mark as a comment, meaning that there is probably no solution through the SDK.
Even if I force SUFaceIsComplex to true, the SUMeshHelperRef class does not perform the correct triangulation of the face, and the relation between the face and the cutting component is not taken into account.
Is there any way to make this relation enable in the live model situation?
Yes that would be definitively a good idea to check this flag (or SUComponentBehavior::component_cuts_opening?) but as I can’t see any way to explode them from the SDK, I don’t know what to do with this flag!
The “hole” caused by SketchUp cutting components is only a display feature. An actual geometric hole does not exist so the geometric database has no information about it. This is why it seems to the end user that the hole moves easily when the cutting component is moved.
The API could use C functions to get these “virtual” inner edge loops from faces that have cutting components “snapped” to them.
@DanRathbun Thanks Dan. You clear answers are really appreciated
You confirm what I was feeling. Anyway, as Sketchup is able to create the geometric holes when using the SUModelCreateFromFile way, I guess that you have some internal algorithms that are able to compute such holes.
Any chance that you expose this mechanism (for example through SUMeshHelperRef) in order to get a really cut geometry?
So, until now, to have a workaround to that problem, I will perform the explode operation at the ruby level.
But what would be the correct explode operation to get the hole?
As a test, I simply tried
Sketchup.active_model.active_entities.each{|e|e.explode if (e.class==Sketchup::ComponentInstance || e.class==Sketchup::Group) }
But the result isn’t the one I expect as the hole is fill!
@Dan About your confusion with SUModelCreateFromFile. The methods loads a SKP file but it gently performs the required process for creating the holes (look at the screenshot at the beginning of the post)
Explode alone will not create the holes. Prior to the explode, you need to determine the edge loops that lie upon the components cutting plane.
A lot of extra stuff. Implementing the feature at the display level would be easier.
With the hope that the core methods for creating holes will be one day exposed in the API, which would be very useful.
You are seeing this in the 2017 version of the C API ?
If so, it is not fully compatible with the live model, yet. But they are slowly working on it, bit by bit.
It will help to have an issue for the “live” openings in the tracker.
No. This is occurs even on Windows. This is due a difference of the way live and readed model are handled. I have to make an issue in gitlab. Not found the time yet!
