So in the image below I want the left to turn into the right.
I want the rectangle to be taken out of the 3 faces without removing the faces entirely. I want to keep the outer loop of the rectangle intact but erase all the edges within it. Could someone help me with the code for this? How do I find and erase only the edges within a rectangle but not the edges that form the outer loop?
I know I can use grep and find but am not sure on how I can specify only the edges that are contained inside of a rectangle. Any help is appreciated.
EDIT: I suppose in this case I would want the bottom edge that helps form the outer loop to be deleted as well… hmmm
