Originally, I was looking for a way of removing the diagonal that is essentially created when moving face vertices to a given plane. I have realised that erasing the line works without destroying the face in which it lies. However, in arriving at this solution I initially tried adding a line between a point on the diagonal and a vertex which did not lie on the diagonal and then moving the internal node to the vertex dragging the attached lines with it. This appeared to work fine until I repeated the process on the same object and I therefor decided to take a closer look at what was going on. My conclusion is that the vertex/face association of the final vertex to which the node is moving is incorrect and thus causes problems when further actions are attempted on the entity.
Below is a test file that shows the problem.
require 'sketchup.rb'
class TTest1
def initialize(*args)
depth = 1000.mm
width = 500.mm
model = Sketchup.active_model
ents = model.entities
pts = []
pts[0] = [0, 0, 0]
pts[1] = [width, 0, 0]
pts[2] = [width, depth, 0]
pts[3] = [0, depth, 0]
face = ents.add_face pts
line = ents.add_line [pts[0], pts[2]]
eraseCommonEdge(ents, line, pts[1])
model.commit_operation
end
def commonEdgeNode(edge1, edge2)
if (edge1.start == edge2.start) || (edge1.start == edge2.end)
return edge1.start
elsif (edge1.end == edge2.start) || (edge1.end == edge2.end)
return edge1.end
else
return nil
end
end
def eraseCommonEdge(ents, line, cornerNotOnLine)
ReportEdgeFaces("1.line",line)
new_edge = line.split(0.5)
ReportEdgeFaces("1.new_edge",new_edge)
vertex = commonEdgeNode(new_edge, line)
ReportVertexFaces("1.vertex", vertex)
if vertex != nil
added_line = ents.add_line(vertex.position, cornerNotOnLine)
ReportEdgeFaces("added_line",added_line)
ReportEdgeFaces("2.line",line)
ReportEdgeFaces("2.new_edge",new_edge)
p = vertex.position
move = p.vector_to(cornerNotOnLine)
transm = Geom::Transformation.translation(move)
ents.transform_entities(transm, vertex) # move internal common node to cornerNotOnLine
ReportVertexFaces("2.vertex", vertex)
end
end
def ReportEdgeFaces(strg, edge)
faces = []
edge.faces.each{|face| faces << face.entityID}
print(strg+".faces= ", faces, "\n")
i = 0
edge.vertices.each{|vertex| ReportVertexFaces(" vertex["+i.to_s+"]", vertex, true); i +=1}
puts
end
def ReportVertexFaces(strg, vertex, suppressCR=false)
ReportVertex(strg, vertex, nil, true, true)
faces = []
vertex.faces.each{|face| faces << face.entityID}
print(" :faces= ", faces, "\n")
puts if !suppressCR
end
def ReportVertex strgIn, p, trans=nil, metricOutput=true, suppressCR=false
if suppressCR
cR = ""
eq = ""
else
cR = "\n"
eq = "="
end
if p == nil
print @Trace.lead, strgIn, "= nil", cR
else
# for some reason Vertex output does not reflect metric environment (but Point3d does)
if trans == nil
trans = Geom::Transformation.new # identity transform
end
pt = p.position.transform!(trans)
if metricOutput
print(strgIn, eq, "(",pt.x.to_mm.round(2),"mm, ", pt.y.to_mm.round(2),"mm, ",pt.z.to_mm.round(2),"mm)", cR)
else
print(strgIn, eq, "(",pt.x.round(2),", ", pt.y.round(2),", ",pt.z.round(2),")", cR)
end
end
end
end
if( not file_loaded?("test1.rb") )
UI.menu("Draw").add_item("Test1"){TTest1.new}
file_loaded("test1.rb")
end
Although the face ID will probably be different for another session the problem can be appreciated form the follwing ruby console output
1.line.faces= [6389, 6399]
vertex[0](0.0mm, 0.0mm, 0.0mm) :faces= [6389, 6399]
vertex[1](500.0mm, 1000.0mm, 0.0mm) :faces= [6389, 6399]
1.new_edge.faces= [6389, 6399]
vertex[0](250.0mm, 500.0mm, 0.0mm) :faces= [6389, 6399]
1.vertex(250.0mm, 500.0mm, 0.0mm) :faces= [6389, 6399]
added_line.faces= [6389, 6408]
vertex[0](250.0mm, 500.0mm, 0.0mm) :faces= [6389, 6399, 6408]
vertex[1](500.0mm, 0.0mm, 0.0mm) :faces= [6389, 6408]
2.line.faces= [6389, 6399]
vertex[1](250.0mm, 500.0mm, 0.0mm) :faces= [6389, 6399, 6408]
2.new_edge.faces= [6408, 6399]
vertex[1](500.0mm, 1000.0mm, 0.0mm) :faces= [6408, 6399]
2.vertex(500.0mm, 0.0mm, 0.0mm) :faces= [6389, 6410, 6408]
You will see that the final vertex thinks that it is at the junction of 3 faces but, in fact there is only 1. I believe that the face ID that remains should be 6399. 6389 and 6408 should have been deleted and I don’t have any idea from where 6410 has come.
I think that this is worth flagging up.
