Hello !
What I try to achievie is having dynamic components instances atrributes values to be set via API - I have a template file which contains all the dynamic components definitions I need, and use it as a basis of new .skp file. When creating file i put component instances in places and try to set their dynamic_attributes values using know keys like ‘Position’. But what happens afrer executing my code is new ‘Position’ key is created in dynamic_attributes dict, but it has empty value.
By dynamic_attributes dictionary i understand one shown in dialog box ( googled image ):
[Dialog Box][1]
I will post full code on monday, i don’t have acces to it today.
SUResult OpenTemplateFile(const char * filePath, SUModelRef * modelRef, SUEntitiesRef * entities)
SUResult res = SUModelCreateFromFile(modelRef, filePath);
if (res == SU_ERROR_NONE)
res = SUModelGetEntities(*modelRef, entities);
size_t r = 0;
SUModelGetNumComponentDefinitions(*modelRef, &r);
fprintf(stdout, "Number of component definitions: %d\n", r);
return res;
SUTransformation GetTranslation(double tx, double ty, double tz)
SUTransformation transformation;
transformation.values[0] = 1.0;
transformation.values[1] = 0.0;
transformation.values[2] = 0.0;
transformation.values[3] = 0.0;
transformation.values[4] = 0.0;
transformation.values[5] = 1.0;
transformation.values[6] = 0.0;
transformation.values[7] = 0.0;
transformation.values[8] = 0.0;
transformation.values[9] = 0.0;
transformation.values[10] = 1.0;
transformation.values[11] = 0.0;
transformation.values[12] = tx;
transformation.values[13] = ty;
transformation.values[14] = tz;
transformation.values[15] = 1.0;
return transformation;
SUResult CreateComponentInstances(SUModelRef model, SUEntitiesRef entities, SULayerRef layerRef)
SUComponentDefinitionRef componentDefinitions[4] = { SUComponentDefinitionRef(), SUComponentDefinitionRef(), SUComponentDefinitionRef(), SUComponentDefinitionRef() };
SUResult result = SU_ERROR_NONE;
size_t retrieved = 0;
size_t len = 4;
result = SUModelGetComponentDefinitions(model, len, componentDefinitions, &retrieved);
SUComponentInstanceRef component1;
SUComponentInstanceRef component2;
SUComponentInstanceRef component3;
SUComponentInstanceRef component4;
result = SUComponentDefinitionCreateInstance(*componentDefinitions, &component1);
result = SUComponentDefinitionCreateInstance(*(componentDefinitions + 1), &component2);
result = SUComponentDefinitionCreateInstance(*(componentDefinitions + 2), &component3);
result = SUComponentDefinitionCreateInstance(*(componentDefinitions + 3), &component4);
result = SUEntitiesAddInstance(entities, component1, NULL);
result = SUEntitiesAddInstance(entities, component2, NULL);
result = SUEntitiesAddInstance(entities, component3, NULL);
result = SUEntitiesAddInstance(entities, component4, NULL);
SUStringRef name = SU_INVALID;
SUStringCreate(&name);
size_t arrayLength = 20;
unichar charArray[20];
size_t numberOfCharsCopied;
result = SUComponentDefinitionGetName(*componentDefinitions, &name);
SUStringGetUTF16(name, arrayLength, charArray, &numberOfCharsCopied);
result = SUComponentDefinitionGetName(*(componentDefinitions + 1), &name);
result = SUComponentDefinitionGetName(*(componentDefinitions + 2), &name);
result = SUComponentDefinitionGetName(*(componentDefinitions + 3), &name);
SUDrawingElementRef component1DE = SUComponentInstanceToDrawingElement(component1);
SUDrawingElementRef component2DE = SUComponentInstanceToDrawingElement(component2);
SUDrawingElementRef component3DE = SUComponentInstanceToDrawingElement(component3);
SUDrawingElementRef component4DE = SUComponentInstanceToDrawingElement(component4);
result = SUDrawingElementSetLayer(component1DE, layerRef);
result = SUDrawingElementSetLayer(component2DE, layerRef);
result = SUDrawingElementSetLayer(component3DE, layerRef);
result = SUDrawingElementSetLayer(component4DE, layerRef);
SUTransformation component1Transform = GetTranslation(10.0, 10.0, 0.0);
SUTransformation component2Transform = GetTranslation(0.0, 10.0, 0.0);
SUTransformation component3Transform = GetTranslation(10.0, 0.0, 0.0);
SUTransformation component4Transform = GetTranslation(20.0, 20.0, 0.0);
result = SUComponentInstanceSetTransform(component1, &component1Transform);
result = SUComponentInstanceSetTransform(component2, &component2Transform);
result = SUComponentInstanceSetTransform(component3, &component3Transform);
result = SUComponentInstanceSetTransform(component4, &component4Transform);
SUEntityRef component1InstanceEntityRef = SUComponentInstanceToEntity(component1);
SUAttributeDictionaryRef component1DynamicAttributesDictionaryRef = SU_INVALID;
SUEntityGetAttributeDictionary(component1InstanceEntityRef, "dynamic_attributes", &component1DynamicAttributesDictionaryRef);
SUTypedValueRef component1AttributeValue = SU_INVALID;
result = SUTypedValueCreate(&component1AttributeValue);
result = SUTypedValueSetInt32(component1AttributeValue, 24);
result = SUAttributeDictionarySetValue(component1DynamicAttributesDictionaryRef, "Position", component1AttributeValue);
result = SUTypedValueRelease(&component1AttributeValue);
const char v[] = { 'F', 'U', 'L', 'L', '\0' };
result = SUTypedValueSetString(component1AttributeValue, v);
result = SUAttributeDictionarySetValue(component1DynamicAttributesDictionaryRef, "FullName", component1AttributeValue);
result = SUAttributeDictionaryGetValue(component1DynamicAttributesDictionaryRef, "FullName", &component1AttributeValue);
SUTypedValueType type = SUTypedValueType_Empty;
SUTypedValueGetType(component1AttributeValue, &type);
SUStringRef stringValue = SU_INVALID;
result = SUStringCreate(&stringValue);
result = SUTypedValueGetString(component1AttributeValue, &stringValue);
size_t strLen = 0;
size_t copied = 0;
result = SUStringGetUTF8Length(stringValue, &strLen);
char * out = (char*)malloc(strLen + 1);
SUStringGetUTF8(stringValue, strLen, out, &copied);
out[strLen] = '\0';
fprintf(stdout, "%s\n", out);
size_t numKeys = 0;
size_t keysRetrieved = 0;
result = SUAttributeDictionaryGetNumKeys(component1DynamicAttributesDictionaryRef, &numKeys);
//SUStringRef * keys = (SUStringRef*)malloc(numKeys * sizeof(SUStringRef));
std::vector<SUStringRef> keys(numKeys);
for (int i = 0; i < numKeys; i++)
SUStringCreate(&keys[i]);
result = SUAttributeDictionaryGetKeys(component1DynamicAttributesDictionaryRef, numKeys, &keys[0], &keysRetrieved);
size_t strLen = 0;
size_t copied = 0;
result = SUStringGetUTF8Length(keys[i], &strLen);
char * out = (char*)malloc(strLen +1);
out[strLen] = '\0';
SUStringGetUTF8(keys[i], strLen, out, &copied);
return result;
int main()
SUInitialize();
SUModelRef modelRef = SU_INVALID;
SUEntitiesRef entitiesRef = SU_INVALID;
const char * fileName = "C:\\1.skp";
SUResult result = OpenTemplateFile(fileName, &modelRef, &entitiesRef);
SULayerRef layerA = SULayerRef();
SULayerRef layerB = SULayerRef();
SULayerRef layerC = SULayerRef();
result = SULayerCreate(&layerA);
result = SULayerCreate(&layerB);
result = SULayerCreate(&layerC);
SUModelAddLayers(modelRef, 1, &layerA);
SUModelAddLayers(modelRef, 1, &layerB);
SUModelAddLayers(modelRef, 1, &layerC);
result = SULayerSetName(layerA, "layerA");
result = SULayerSetName(layerB, "layerB");
result = SULayerSetName(layerC, "layerC");
result = SULayerSetVisibility(layerA, true);
result = SULayerSetVisibility(layerB, true);
result = SULayerSetVisibility(layerC, true);
result = CreateComponentInstances(modelRef, entitiesRef, layerA);
SUResult saveResult = SUModelSaveToFile(modelRef, "C:\\newModel.skp");
SUModelRelease(&modelRef);
SUTerminate();
return 0;
