I’m trying to iterate through a drawing’s components to record length attributes. It’s worked fine up to this point, but this particular drawing I have has outdated values when I try to read them from the API. You can easily see this using Aerilius’ Attribute Inspector. When entity type is changed from component definitions to drawing elements, meter look fine:
What’s going on here? Is the drawing file corrupted? Or should I be grabbing “drawing elements” in my plugin to begin with and how would I do that?
You may also need to look at the “dynamic_attributes” dictionary attached to the component definition.
That’s what I’m doing. It doesn’t match the actual value. I expect
entity.definition.attribute_dictionaries["dynamic_attributes"]["meter"]
to return 0.374233, as is shown in the Component Attributes windows, but instead I get 1.03471.
I figured it out. entity.attribute_dictionaries will ONLY contain dynamically updated attributes while definition.attribute_dictionaries will contain static attributes.
This is what I ended up doing to iterate through all dynamic attributes:
Sketchup.active_model.entities.each_with_index do |entity|
processEntity(entity)
end
def processEntity(entity)
if entity.typename == "Group"
entity.entities.each{ |e|
processEntity(e)
elsif entity.typename == "ComponentInstance" && entity.definition
if entity.definition.attribute_dictionary("dynamic_attributes")
attributes = entity.definition.attribute_dictionary("dynamic_attributes")
**Do stuff with your static attributes**
if(entity.attribute_dictionary("dynamic_attributes"))
attributes = entity.attribute_dictionary("dynamic_attributes")
**Do stuff with your dynamic attributes**
end
end
entity.definition.entities.each{ |e|
if e.typename == "Group"
processEntity(e)
end
end
end
have a look at this link typename
john
Firstly, I would call the defintion’s attributes default, not static.
There are a number of issues with your example. Listed in order of importance:
CRITICAL:
Does not actually process the instance’s attributes, in preference to the component’s attributes.
Does not handle the oft situation where dynamic components have nested dynamic components.
Using slow String compare of the Sketchup::Entity#typename() method.
- Instead, use:
Object#is_a?(ClassIndentifier)
IMPORTANT:
Using recursive methods on very large models can cause out of memory errors or crash SketchUp.
Creating multiple String objects that have the same value.
- Declaring literal strings, causes the Ruby interpreter to call
String::new(literal_string),
creating [unnecessary] separate String instance objects.
- Instead, declare one referenced String instance object, and reuse the reference:
dict = "dynamic_attributes" or even better a constant or a module variable.
Tab indentation characters paste into forum as 8 space indents.
- Making hard to read code, … often causing unwanted horizontal scrolling.
- Ruby uses 2 space indents.
NOTABLE:
- Ruby does not need boolean expressions wrapped in parenthesis (like Javascript.)
- Doing this is a violation of most published Ruby style guides.
- When unneeded, it just clutters the code.
- Ie, there should always be a space between the
if or unless and it’s boolean expression.
- But they can be used for clarity, or forcing particular evaluation order,
when the boolean expressions are compound or complex.
TRIVIAL:
Here is a similar example (that still uses a recursive method call):
# encoding: UTF-8
module Author
module SomePlugin
DICT = "dynamic_attributes"
@@loaded = false unless defined?(@@loaded)
class << self # this module's singleton proxy class instance
def do_stuff()
# ** Do stuff with your dynamic attributes **
if @inst_atts # nil if empty
puts "Component Instance has #{@inst_atts.size} dynamic attributes."
else
puts "Component Instance has no dynamic attributes.\n"<<
"Using only the definition's atttributes."
end
if get_value("LenX") > 30.3
puts "Length is too long !"
end
end ###
def get_value(attr)
# Check the instance's dictionary first:
# It will be nil if empty, or the attribute will be nil if unset.
if !@inst_atts.nil? && !@inst_atts[attr].nil?
return @inst_atts[attr]
else
return @defn_atts[attr]
end
end ###
def process_entity(entity) # <-----<<< ### ! Recursive Method ! ###
if entity.is_a?(Sketchup::Group)
entity.entities.each {|e|
process_entity(e)
elsif entity.is_a?(Sketchup::ComponentInstance)
if entity.definition.attribute_dictionary(DICT)
# ... then it is a dynamic component, so:
@defn_atts = entity.definition.attribute_dictionary(DICT)
@inst_atts = entity.attribute_dictionary(DICT) # nil if empty
# **Do stuff with your dynamic attributes**
do_stuff()
@defn_atts = @inst_atts = nil # release the references
end
entity.definition.entities.each {|e|
if e.is_a?(Sketchup::Group) ||
process_entity(e)
end
end
end ###
end
if not @@loaded
cmd = UI::Command::new("Process Components") {
Sketchup.active_model.entities.each do |entity|
begin
rescue Exception => e
puts e.inspect
end
end
## add cmd to top menu, toolbar or context menu here.
end # run once block
end
end
Very informative post. Thank you very much, this helps a lot as a .NET dev trying to string together a plugin!
