Hi guys.
Just to register that i have the very same problem with Sketchup 2018 taking a looooooong time to open files. (Eternal time)
And then after read this post and keeping the materials tab minimized when I close Sketchup, this issue seen to have desapeared.
I have 4 Computers with Sketchup installed, and this problem only appear in one of then, a I9 coffe lake with Nvidea 1660.
Is there a way to ensure that Materials Tray always start closed?
When I close the files, I’ve been always checking that the Materials are closed, but sometimes when I open the same file, Materials are open again and it takes a looong time to open…
Seens random to me…
The SketchUp API does not allow closing or collapsing any of the panels on Windows. They might collapse on Mac if the UI::show_inspector("Materials") is called when it’s open.
Otherwise the settings are held in the preferences JSON files. But we cannot change them whilst SketchUp is running because it overwrites them upon closing.
The closest hopefully we could come automatically (within SketchUp) is if the “Materials” inspector is wrapped in it’s own tray, then the tray can have a shortcut keychord assigned, and then a little plugin with an AppObserver that uses the Windows Scripting Host’s Sendkeys method to send the keystroke to SketchUp to close the tray.
However I haven’t yet tested whether SketchUp will accept such keystrokes when it’s within the shutdown cycle.
The only other option might be an external process that waits for SketchUp to close and then “tweaks” the JSON file. (Or is used to open SketchUp and does the “tweaking” before SketchUp loads.)
I notice something unusual:
When i run the System Checkup 2020 it didn’t show any problems.
When i run the System Checkup 2019 it shows a warning message:
When I click on the link(s) I get the 2019 Checkup download but where do you get the 2020 Checkup one? I like the way Trimble have listed 2 download links with absolutely no info on which is which. That’s handy.
Hi Colin, I only get one line when I select 2020 in the drop down list to the right but does seem funny that 2019 has two lines & be good to fix. It would be better if you could fix the clipping plane issue too
