Taxsola
November 20, 2021, 7:09pm
1
I’m implementing Modus UI on my extension.
I’ve downloaded and linked “modus.min.css ” and “modus-icons.css ” locally.
Most of components works fine but not accordions, dropdowns and tabs .
They stay frozen/stuck on first state, can’t select other options.
Is it a “bootstrap.js” issue? How to fix it?
Basically a copy-paste from modus docs Im using for tests:
(I’m testing on SU2018, Win10)
dialog = UI::HtmlDialog.new({
:dialog_title => "Modus UI tabs test (stuck error)",
:preferences_key => "com.sample.plugin",
:resizable => false,
:style => UI::HtmlDialog::STYLE_DIALOG
(html = "<!DOCTYPE html>
<html>
<link rel="stylesheet" href="https://modus.trimble.com/css/modus.min-1.3.1.css">
<link rel="stylesheet" href="https://modus.trimble.com/assets/0.5.1/fonts/modus-icons.css">
<body class='m-3 bg-panel-background'>
<ul class='nav nav-tabs' id='exampleTab' role='tablist'>
<li class='nav-item'>
<a class='nav-link active' id='exampleFirstTab' data-toggle='tab' href='#exampleFirst' role='tab' aria-controls='exampleFirst' aria-selected='true'>First tab</a>
</li>
<a class='nav-link' id='exampleSecondTab' data-toggle='tab' href='#exampleSecond' role='tab' aria-controls='exampleSecond' aria-selected='false'>Second tab</a>
</li>
<a class='nav-link' id='exampleThirdTab' data-toggle='tab' href='#exampleThird' role='tab' aria-controls='exampleThird' aria-selected='false'>Third tab</a>
</li>
</ul>
<div class='tab-content py-3' id='exampleTabContent'>
<div class='tab-pane fade show active' id='exampleFirst' role='tabpanel' aria-labelledby='exampleFirstTab'>
<h5 id='first-tab-content'>First Tab Content</h5>
<p>TEXT TEXT TEXT.<br></p>
</div>
<div class='tab-pane fade' id='exampleSecond' role='tabpanel' aria-labelledby='exampleSecondTab'>
<h5 id='second-tab-content'>Second Tab Content</h5>
</div>
<div class='tab-pane fade' id='exampleThird' role='tabpanel' aria-labelledby='exampleThirdTab'>
<h5 id='third-tab-content'>Third Tab Content</h5>
</div>
</div>
<div class='accordion' id='accordionCodeExample'>
<div class='card'>
<div class='card-header' id='accordionHeadingOne' data-toggle='collapse' data-target='#codeCollapseOne' aria-expanded='true' aria-controls='codeCollapseOne'>
<h6 class='mb-0' id='collapsible-group-item-1'>Collapsible Group Item #1</h6>
</div>
<div id='codeCollapseOne' class='collapse show' aria-labelledby='accordionHeadingOne' data-parent='#accordionCodeExample'>
<div class='card-body'>
This is the first item's accordion body.
</div>
</div>
</div>
<div class='card'>
<div class='card-header' id='accordionHeadingTwo' data-toggle='collapse' data-target='#codeCollapseTwo' aria-expanded='false' aria-controls='codeCollapseTwo'>
<h6 class='mb-0' id='collapsible-group-item-2'>Collapsible Group Item #2</h6>
</div>
<div id='codeCollapseTwo' class='collapse' aria-labelledby='accordionHeadingTwo' data-parent='#accordionCodeExample'>
This is the second item's accordion body.
</div>
</div>
</div>
<div class='card'>
<div class='card-header' id='accordionHeadingThree' data-toggle='collapse' data-target='#codeCollapseThree' aria-expanded='false' aria-controls='codeCollapseThree'>
<h6 class='mb-0' id='collapsible-group-item-3'>Collapsible Group Item #3</h6>
</div>
<div id='codeCollapseThree' class='collapse' aria-labelledby='accordionHeadingThree' data-parent='#accordionCodeExample'>
This is the third item's accordion body.
</div>
</div>
</div>
</div>
<div class='modal-footer'>
<div class='dropdown'>
<button class='btn btn-primary dropdown-toggle' type='button' id='dropdownMenuButton' data-toggle='dropdown' aria-haspopup='true' aria-expanded='false'>Dropdown</button>
<div class='dropdown-menu' aria-labelledby='dropdownMenuButton'>
<a class='dropdown-item active' href='#'>Action1</a>
<a class='dropdown-item' href='#'>Action2</a>
<a class='dropdown-item disabled' href='#'>Action3</a>
</div>
</div>
</div>
</html>
dialog.set_html(html)
dialog.set_size(500, 600)
dialog.show
Thanks
I don’t know whether it is the cause, but your HTML has 2 errors.
(1) The <link>
elements should be in either <head>
or <body>
depending upon whether their rel
type is body-ok . Your <link>
elements are in neither as your HTML document does not have a <head>
element.
(2) Your document’s <body>
element has no closing </body>
tag.
dezmo
November 20, 2021, 9:23pm
3
…as well as some error in your Ruby code:
You are using " (double quote ) inside others " (double quote ), I guess you got some error if your code really looks like that…
I would rather writing like this:
html = %{
<!DOCTYPE html>
<html>
</html>
I’m not sure about the Modus UI (did not checked before…), but I guessing that will Requires JavaScript component, but I do not see anything like this in your code.
(There’s a lot you can do with just CSS, so I might be wrong.)
Taxsola
November 20, 2021, 11:24pm
4
You guys are completely right, thanks.
It’s now working perfectly!
I’ve:
created head block for the links
closed the body block
replaced double quotes from " to ' . (also good to know about % thing)
Yeah, that wouldn’t run. Those are the online links; I forgot the " before posting, sorry.
added more dependencies including that “bootstrap.js ” one.
I just couldn’t find the file to download. Thanks for @eneroth3 and @thomthom for all github work. It should be easier to get from trimble’s page.
Modus dependencies files: (missing just “modus-icons.css”)
obs: I’ve yet no clue about what they do exactly, linked them all just so I have not to worry about such dependencies anymore. It works! don’t judge me!
Working code:
:dialog_title => "Modus UI example",
<html>
<head>
<link href='../modus.css' rel='stylesheet'>
<link href='../modus-icons.css' rel='stylesheet'>
<script src='../jquery.js'></script>
<script src='../bootstrap.bundle.min.js'></script>
<script src='../vue.js'></script>
</head>
</li>
</li>
</li>
</ul>
</div>
</div>
</div>
</div>
<div class='card'>
</div>
</div>
</div>
</div>
<div class='card'>
</div>
</div>
</div>
</div>
<div class='card'>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</body>
</html>
dialog.show
Thanks yall saved the day again
tt_su
November 22, 2021, 10:34am
5
We’ve be very interested in seeing the final result with Modus if you’d be willing to share with us.
Taxsola
November 22, 2021, 5:51pm
6
Sure!
I’ve just posted (it’s not the above code, it was just testing components):
Update preview (modus UI implementation)
There I’ll be posting updates
Maybe I should open another thread for showing my modus 1st contact experience while suggesting some improvements.
