good morning all
need help with XML file.
need to export direct file from sketch up to XML
thanks
good morning all
thanks
help please
DAE uses an XML schema for for it’s data - so that may be the closest to what you are describing.
What software is requesting XML?
Please explain more. XML is a markup language, not a specific format. What schema do you need the XML to use?
need to export for machine cutting that work by XML format
Still not enough info. What machine and what XML schema does it require. Don’t make us do your homework for you!
Where can I try this extension?
Hi, its still beeing devoloped and will be licensed when its done (not free).
Please post when it’s ready, also if you need any testers, thanks
Whats your purpes regarding your want for the plugin? just Interesting to know.
My interest would be taking survey and/or design from Civil 3D to SketchUp to texture and render for some visualizations, right now recreating sites by importing contours and using topo shaper to create terrains so this would hopefully eliminate that step.
it most definitely do. Anything spesific regarding survey?
