I’m a Wood Worker and I need to be able to be able to show angles in degree’s when dimensioning. I would appreciate any suggestions on one that is proven to be good.
Thanks,
Thanks,
There’s an angular dimension plugin at Sketchucation that might work for you.
Thanks Dave
Jim Wilson
There’s a later version which puts the dimension text in the plane of the angle, not as Leader Text - see
It’s a significant enhancement of Steve Baumgartner’s original draw_angle_dim (Angular Dimension v4.0) that @DaveR gave you a link for. I worked with Steve to develop it.
See which you prefer - they both do the basic job you are asking for.
Hi John,
Thanks for your info. Is there any way I can remove this one?
Jim Wilson
The most robust way to remove it is to go to your Plugins folder and delete the file SB_draw_angle_dim.rb file and the folder of the same name without .rb at the end.
Alternatively, if you used the Sketchucation Extension tool to install it, go to Extensions/Sketchucation/Sketchucation Plugins Uninstaller and use that to remove it.
Thanks John
Jim Wilson
