In Layout, is there a way to rotate dimension labels 90 degrees. For example, rotate the dimension label on a vertical dimension to read horizontal?
select it and check the dimension panel on your right.
you can have the text horizontal, vertical, aligned with the dimension or perpendicular to the dimension.
