SketchUp 2024?
“Good morning, the 2024 version does not open files from previous versions. Can anyone help me?”
Gracias
it does. all sketchup versions can open files from previous versions. you’ll get a message on screen telling you that doing so will prevent reopening the files on your older versions, but it works.
unless you mean that it doesn’t save to older versions ?
do you have a specific file that refuses to open in 24? can you share it ?
It only opens files created with the 2024 version; it doesn’t open any files from previous versions.
this is a 2017 file open in 2024. it says that if I save it in 24 I won’t be able to open it in 17 anymore. that’s all.
do you get error messages or anything ?
It directly gives an error and closes the program.
There must be something else. Either the file you are trying to open is corrupted, or your installation is in fault or incomplete. Try repairing your installation. Locate the installer file, right-click, select “Run as administrator” and click on “Repair” when the dialog box appears.
Post the file you are trying to open for others to take a look.
and what is the error message ?
also, yeah, like I said, and Anssi too, share the file so we can check if it opens on our machines
Sorry, but I can’t publish it; it’s a work file.
I will inform the IT service of your help. I can’t share the files because they are company material. Thank you very much for your help!!
