I have dynamic components for cabinets.
In Sketchup, is there a way to select the dynamic components based on their value in components options?
The conditions would be like an object w/ A_ItemCode equal to 33 or any objects w/ B_CarcassWidth greater than 800mm.
This could be done with Ruby…
model = Sketchup.active_model
sel = model.selection
dict = 'dynamic_attributes'
code33 = []
sel.each do |dc|
check = dc.get_attribute( dict, 'item_code')
if check == '33'
code33 << dc
end
end
sel.clear
sel.add code33
test.skp (98.4 KB)
Thank you!
Will you please give some suggestions on how and where to learn Ruby and Sketchup API?
Because there are many more ideas I want to explore now that I see the power of programming from your answer.
Liked I want to align the selected dynamic components on x-axis with like 10cm distances w/ each other. I think Ruby and Sketchup API can help but no idea where to start.
After debugging process, I found that Ruby uses lowercases.
Glad it worked for you! @rtches link to Dans resources is a great place to start, and you can always search and post here with questions. It’s a pretty steep learning curve and it can be quite a bit of fun too…
