I’m having trouble redrawing the dynamic component
I´m trying to make some changes via ruby console, in a component i have drawn in sketchup, heres the code:
Get the current selection
selection = Sketchup.active_model.selection
Check if something is selected
if !selection.empty?
Iterate over the selected items
selection.each do |item|
# Check if the item is an instance of a component
if item.is_a?(Sketchup::ComponentInstance)
# Change the value of the ‘acab_pta’ attribute to the desired new value (replace ‘NewValue’ with the desired value)
item.set_attribute(‘dynamic_attributes’, ‘acab_pta’, ‘108’)
puts “Attribute ‘acab_pta’ changed for the selection!”
  # Force a screen refresh to reflect the changes
  item.model.active_view.refresh
else
  puts "The selected item isn't a Component Instance."
end
end
else
puts “Nothing is selected. Please select at least one component to apply the change.”
end
the problem is i am actually have to open the context menu manually and reload my component to the changes apply to the view, anyone got a hint on how to solve this?
sorry my bad english, its not my mother language, also thank you for answering
Just making the code readable
    else
    end
  end
else
end
This is just a guess…perhaps something has to occur to cause the dynamic component to notice the change? There is no published API for DCs. Everything known about coding to them was puzzled out experimentally.
just addying some informations:
im changing an attribute i created, acab_pta, it controls some features in my component.
i was thinking it may be related to the fact it´s created by me? perhaps if i was changing other attribute it could work?
See answers in the Dynamic Components category …
Also:
[How to] Post correctly formatted and colorized code on the forum?
@sWilliams Your post has smartquotes in the code.
