Hello SketchUp community,
I’m developing a Ruby plugin for kitchen cabinet layouts. I have a challenging UV texture alignment problem and hope someone can help.
The Setup:
A horizontal countertop group (
pianoTopOrizz) that forms an L-shape at each corner. Texture is applied usingposition_materialwith 2 points: anchor at the front corner apex + direction U along the main cabinet run. -
Separate vertical tile panel groups (
pianoTileVerticale) positioned against the wall, one per side of the corner. These are created in a group that may have a non-trivial rotation transform when the corner has a deviation angle ≠ 0. -
Tile size: 10×10 cm, texture bitmap: 50×50 cm (5×5 tiles), set with
mat.texture.size = [50.cm, 50.cm].
The Problem:
Corner deviation = 0° (perfect right angle): UV alignment between top and vertical panels is perfect
— grout lines continue seamlessly from horizontal to vertical. -
Corner deviation ≠ 0° (e.g., 8° or 12°): the vertical panel’s texture becomes misaligned with the top
I’ve tried several approaches:
Approach 1 — 1 point (default orientation)
p0_local = anchor_world.transform(group.transformation.inverse)
p0_f = p0_local.project_to_plane(face.plane)
face.position_material(mat, [p0_f, Geom::Point3d.new(0,0,0)], true)
The default orientation is parallel to the group’s local axes, which differs from the oblique top direction by the corner angle → visible offset = depth × sin(angle) mod tile_size (e.g., 65 × sin(12°) mod 10 ≈ 3 cm).
Approach 2 — 2 points, direction U from top (world space vector):
v_u_world = (second_pt - anchor_pt).normalize # same direction as top’s U
v_u_local = v_u_world.transform(group.transformation.inverse)
v_u_local.z = 0; v_u_local.normalize!
p1_f = p0_f.offset(v_u_local, 50.cm)
face.position_material(mat, [p0_f, Geom::Point3d.new(0,0,0),
p1_f, Geom::Point3d.new(1,0,0)], true)
Better alignment, but tiles appear distorted (very small, ~5×5 cm) when the group has a rotation transform. I suspect the world->local vector transformation is incorrect or the projection onto the face plane is wrong.
My Questions:
With
position_material(..., true)(local coordinates), should direction vectors be fully transformed into the group’s local coordinate system, or does SketchUp handle the group transform internally? -
For a vertical face inside a group with a rotation transform, what is the correct procedure to project a world-space direction vector onto the face plane so the texture scale is preserved (50×50 cm)?
Is there a standard/recommended technique in Ruby for aligning UV between an adjacent horizontal surface (top) and vertical surfaces (backsplash) when one group has a non-trivial rotation?
Reference images:
The images show a kitchen with two non-90° corners (left: 8°, right: 12°). Letters A–L and numbers 1–9 mark the grout line reference points where horizontal top and vertical panels should align.
V1: Full overview — left corner (8°) with labels A–L, right corner (12°) with labels 1–9
V2: Zoom — left corner 8°, points A–L show expected alignment locations
V3: Zoom — right corner 12°, points 1–9 show same expected alignment
Thank you very much for any guidance!
