Hello everybody,
I’m trying to find a reliable method to retrieve the correct global position of a Face or Edge in SketchUp. Most of the time, the entity is part of the global model, but it can also be nested inside one or more groups or components, which themselves can be nested within other groups or components.
Problem:
- The
FaceorEdgeis not selected. - I cannot rely on user input to select the entity (e.g., using
PickHelper). - I want to receive the global positioning of a
FaceorEdge(or the correct transformation).
What I have so far:
Here’s the code I am currently using to handle cases where the Face or Edge is inside a ComponentInstance:
def get_parent_transformation
found_instance = nil
if !parent.is_a?(Sketchup::Model) && (self.is_a?(Sketchup::Face) || self.is_a?(Sketchup::Edge))
vertices_local = vertices.map { |vertex| vertex.position }
instances = parent.instances
instances.each do |instance|
vertices_global = vertices_local.map { |point| point.transform(instance.transformation) }
match = vertices.each_with_index.all? do |vertex, index|
vertex_global_position = vertex.position.transform(instance.transformation)
puts vertex_global_position.distance(vertices_global[index])
(vertex_global_position.distance(vertices_global[index]) < 0.001)
end
if match
found_instance = instance
break
end
end
elsif !parent.is_a?(Sketchup::Model) && self.is_a?(Sketchup::ComponentInstance)
found_instance = find_parent_instance(self)
end
if found_instance
parent_transformation = found_instance.get_parent_transformation * found_instance.transformation
else
parent_transformation = Geom::Transformation.new
end
end
Current Behavior:
- This code works when the
FaceorEdgeis nested one level deep inside aComponentInstance. - It works by comparing the global and local positions of vertices to determine the correct instance.
Problem I’m Facing:
- The issue arises when the
FaceorEdgeis nested deeper within multiple levels ofComponentInstances (i.e., aComponentInstanceinside anotherComponentInstance). - In this case, I’m unsure how to accurately identify which
ComponentInstanceis the correct parent, especially when there are multiple instances of the sameComponentDefinition.
Question:
How can I reliably determine the correct ComponentInstance (or global positioning) when a Face or Edge is nested deeper inside multiple component hierarchies? Is there a way to ensure that I apply the correct transformations recursively when dealing with complex nesting?
Any insights or suggestions would be greatly appreciated!
