Hello,
In sketchup API, I was trying to retrieve the position of outer loop vertices of a face using:
face.outer_loop.vertices
However, I am not able to get the position in the global fame of reference.
Thanks!
@thomthom
Hello,
Thanks!
@thomthom
Positions obtained from vertices are always locale to their parent - not global.
In order to work out the global position you need the combined transformation for all the parent instances. How you do that depend on context of how your extension work.
For instance, if your extension works on the active_entities at all time, then you can obtain the transformation via model.edit_transform.
But if you are traversing the whole model, say if you do a model export, then you need to keep track of the instance transformations as you dig down into the model hierarchy.
module Example
def self.get_entities(instance)
if entity.is_a?(Sketchup::Group)
entity.entities
else
entity.definition.entities
end
end
def self.walk(entities, transformation = IDENTITY)
entities.each { |entity|
case entity
when Sketchup::Face
global_points = face.outer_loop.vertices.map { |vertex|
vertex.position.transform(transformation)
# Do stuff to global position of vertices here...
when Sketchup::Group, Sketchup::ComponentInstance
entities = get_entities(instance)
walk(entities, entity.transformation * transformation)
end
end
end
I used the following:
mod = Sketchup.active_model # Open model
ent = mod.entities # All entities in model
sel = mod.selection # Current selection
def walk(face, transformation = IDENTITY)
end
sel[0].entities.each { |ent|
if ent.typename=="Face"
puts walk(ent)
end
On the graphics screen, I selected a group, which contains some faces. But still I am retrieving the local coordinates. Is there anything wrong with my understanding?
Thanks!
Okkkk Got it now!!
This worked for me:
end
puts walk(ent, sel[0].transformation)
end
Thanks @thomthom
Is very slow. Using Ruby core is_a?() method is much faster:
ent.is_a? Sketchup::Face
Hey, on the margins of this question, I would ask why when I created a new point using:
pt = Geom::Point3d.new(1,0,1)
puts pt
(0.0254m, 0m, 0.0254m)
It returning values in inches? (I guess)
I have set meters as the model unit though
Is it the same issue as global and local like it follows the parents or something like this?
Thanks
The SketchUp engine uses Inches internally.
pt = Geom::Point3d.new( 1.mm, 0, 1.mm )
See the API methods added to the Numeric class:
… and the API specific Length class:
Also see ThomThom’s blog:
Thanks @DanRathbun
appreciate it!
A strong +1 for that - it’s the number one performance killer I see in SketchUp extensions. To the point I even wrote a little article at one point:
Oh I see. Thanks!
