Hello guys,
I was trying to follow this tutorial to simply read a .json file but…
if I try:
require "json"
@file = File.open("/file_path/file.json")
@data = JSON.load(@file)
I get:
Error: #<JSON::ParserError: 814: unexpected token at '{
"use_defaut":"true",
"skp_path":"skp path here",
"stl_path":"stl path here",
If I try:
require "json"
@file = File.read("/file_path/file.json")
@data = JSON.parse(@file)
I get:
Error: #<JSON::ParserError: 776: unexpected token at '{
"use_defaut": "true",
"skp_path": "skp path here",
"stl_path": "stl path here",
the .json file is pretty simple:
Is something wrong on the .json file? I’ve tried some variations such double/simple quote, “:”, “=>”
nothing seems to work.
any advice?
thanks
There is a frivolous comma after the last data pair.
Might be an encoding issue. Your JSON should be UTF-8 encoded.
Start with a hash in Ruby and have the JSON
lib create the string and write it to the file path.
json = Hash[
"use_defaut", "true",
"skp_path", "skp path here",
"stl_path", "stl path here"
].to_json
File.write("/file_path/file.json", json)
And then try to read it back into a hash with Ruby.
Lastly, it is not necessary to use a @var for the string read from the file as you’ll just convert it to a hash anyway. Instance variables are for persistence and access across the scope of an instance object.
You’ll be doing this file read within a method and the string reference from the file will go out of scope when the method ends, so it’ll automatically get “cleaned up” by Ruby’s garbage collector.
thanks for ur quick reply Dan, gonna try it right now
here is the generated json from ruby:
{"use_defaut":"true","skp_path":"skp path here","stl_path":"stl path here"}
It was just that comma! no errors now.
thanks a lot Dan
