Loading file problem
Dear friends,
#    unless file_loaded?("wall.rb")
    UI.menu("Plugins").add_item("Wall") {
    Sketchup.active_model.select_tool(Wall.new)
#    file_loaded("wall.rb")
#    end
if I active 3 line codes, ruby send me "Nil result (no result returned)" but it works well when these 3 lines are deactivated. Can you tell me what is my problem?
Are you talking about the 3 lines in comment? (With the # in front of it)
I am on my phone right now, but, could another dev please add __file__ instead of wall.rb
How many other plugins might also use the simple filename "wall.rb" ?
The methods file_loaded() and file_loaded?() are global methods that put text Strings into a shared global array named $loaded_files.
This means you will need to use a unique filepath string to test with.
  unless file_loaded?(File.join(__dir__,"wall.rb"))
    file_loaded(File.join(__dir__,"wall.rb"))
  end
Secondly, this code snippet must be within the module where the Wall class is defined.
It is actually __FILE__, and I showed using Ruby 2.x’s __dir__ method.
So … @majid866 you can also use …
  unless file_loaded?(__FILE__)
    file_loaded(__FILE__)
  end
By the way @majid866, this comes right from the example in the API documentation.
Great @DanRathbun. I know it was uppercase, but didn’t care to bother on this touch screen cellphone thing, sorry :slight_smile:
I already was happy to have added these backquotes and underscores
