Projecting outer shape on surface
Hi all,
I’m new to Sketchup, new to ruby, new to this forum, but I like it all a lot!
I can’t figure this one out though: I am trying to figure out a way to project an odd-shaped object to a 2D surface and take the outer most edges only. Think of it as the shadow an object casts on the ground when the sun is exactly above it.
I can do this using Sandbox’s Drape tool and then erasing all the inner edges, but I feel like I’m missing an obvious method to code this. I have a messy work around to recreate some of the Drape tool when I’ve selected a group:
  model = Sketchup.active_model
  model.start_operation('Test', true)
  group = model.selection[0]
  group.entities.each{|e|
    if e.is_a? Sketchup::Edge
      p1 = e.start.position.clone
      p1.z = 0
      p2 = e.end.position.clone
      p2.z = 0
      model.entities.add_edges p1, p2
    end
  model.commit_operation
Could anybody point me in the right direction and help me out?
Thanks!
Bob
Thanks!
Instead of using edges, you should use the face which allows you to specify just the outer loop of edges that define the face. Also, since you are using group entities, you need to transform them back to the model space. Something like this
trans = group.transformation
  if e.is_a?(Sketchup::Face)
    pts = e.outer_loop.vertices.map{|v|v.position}
    pts.each{|p|p.transform!(trans); p.z=0}
    model.entities.add_edges(pts<<pts[0])
  end
Thanks sdmitch, using the face was the solution, that’s great!
It took me a while to understand the transformation trick and why you’d have to add pts[0] again, but it makes perfect sense to me now.
