Problems using the outer shell function
I can’t use the outer shell function anymore. It keeps telling me that the object is not solid, but it doesn’t make sense as it doesn’t work for objects I’ve drawn with the regtangle as well.
they also need to be solid groups or components for it to work…
john
If @john_drivenupthewall 's suggestion does not help, share the model that is causing you problems and we can take a look!
A rectangle is 2D only, you need a solid 3D geometry for the Solidtools.
