Can anybody help with importing this file please?
J801-06 Proposed Barn (B) Plan and Elevations.dwg (47.5 KB)
hello,
thereâs nothing in your dwg but 5 missing xref.
the one who sent it to you should bind the xref to the file so that it is not external anymore.
And since it is an export from archicad, ask him/her to export it as an .skp file instead of dwg
Hi Paul
Thanks for your response. I have now asked for the original Archicad (3ds) file as the .skp they sent didnât have the level of detail the dwg file had.
I donât have the level of understanding about xrefs etc but if I donât have any success Iâll copy and paste your message on to the originator of the file.
Many thanks
xref are references. The main file (that you sent) calls 5 other .dwg files, 1 for each elevation and the ground floor plan. If I try to open this file, those xref are missing, and sketchup canât handle them because they are external to the drawing.
If you have autocad and if they sent you those external drawings along the main one, simply type xref and hit enter, youâll get the list of attachments.
right click on each of them and pick âbindâ or âinsertâ to incorporate them in the file.
Another option is to import each elevation + the plan individually in sketchup, since you are going to rotate them differently anyway (still assuming they sent you those xrefs !!)
for info, here are the files youâre looking for :
3ds is not archicad file format, archicad files are .pln and if you donât own it you wonât be able to do anything with it, and if the .skp export from their model was not detailed enough, I doubt the .3ds export will be any different
Following your response Iâve discovered a folder âXrefed ARCHICAD Viewsâ that came with the DWG file that I was first sent! These successfully import into SketchUp as separate 2D plans and elevations as you mentioned which is what I was after. Many thanks for providing the expertise to get there.
AFAIK Archicad can be used as a viewer without a license.
Archicad can export directly to the SketchUp format from its 3D views. 2D items added to floor plans and sections wonât be expoerted, only the full 3D model. Archicad has no actual âlevel of detailâ setting like Revit.
perhaps, but the idea here was to get material from it to work with inside sketchup
youâre welcome ! glad you made it through
