Is there a way to pick objects outside the context once you are inside a group or component?
Looks like, not really. However InputPoint can do something… ![]()
class TestToolPH
def activate
@ip = Sketchup::InputPoint.new
end
def onMouseMove(flags, x, y, view)
@ip.pick(view, x, y)
ph = view.pick_helper
ph.do_pick(x, y)
view.tooltip = "ph:#{ph.picked_edge}\nip :#{@ip.edge}"
view.invalidate
end
end
Sketchup.active_model.select_tool(TestToolPH.new)
… and you can compare InputPoint#instance_path to Model#active_path to be sure that the pick is outside the current active edit path. (nil means that nothing is yet picked.)
