Hi Boris.
The new version has a lot of cool stuff! Can you share what your intended workflow will be for scribed parts that need be oversize i.e. toe kick trim, fillers now that the oversize feature has been abandoned?
Hi Boris.
The last LAB version integrate the capabilities to oversize parts individually in addition to material oversize.
The main difference is that it now changes the raw dimensions instead of finished dimensions.
Let me know if it could be a solution for you.
Iβll try it and give feedback. I think it probably solves it for us. Currently the way we do things is to draw every part the right size that it will exist in the world so that it shows up correctly in our shop drawings, then the cut list handles any oversize requirements.
And itβs not just for scribes. I also use the oversize properties for multi-step fabrication scenarios like panel glue ups where itβs important to start with pieces that are wider and longer than needed and are then trimmed to final dimension at a later step.
