Names of named groups reseting to default "group" name when grouping
Sketchup Pro 2023 latest version seems to have a problem when I group named groups.
Lets say I create 4 groups, called “part 1”, “part 2”, “part 3”, “part 4”, then I want to select them and group the four parts as a group with the intention of calling that “assembly”. As I select the four groups for grouping into the new group, at some point, some or all of the group names default back to “group”.
I have been using SketchUp for 10+ years so I don’t think it’s “operator error”, but there’s always that possibility.
Is this a known problem?
DG
I assume that it happens when you select them in the outliner panel right ?
if so, it’s a known bug, we hoped to have one last update in 2023 but I guess it’ll be fixed in 2024.
normally, selecting stuff on screen (and not in the outlier) shouldn’t rename groups. normally.
Yes, it’s when I select in the outliner.
Thanks for the info.
DG
Not seeing it in the bug fix list. Guess I’ll have to try it once I have installed 2024, but I’m finishing a job in 2023 before I switch (just incase…)
David
I did a quick test using SU 2024 and it seems to work OK.
That’s really good to hear. After a month what’s your overall impressions of Sketchup 2024?
After the hassle of SU 2023 with these kinds of little issues in Outliner, I’m reluctant to make the leap.
