I am building a 18th century naval cannon carriage. I am using a Macbook with the pro version. I need to put the wheels onto the spindles of the axletrees. I am trying to center the wheel and then snap on the center of the spindle to place it properly. This is proving very difficult for me because the wheel obscures the view of the end of the spindle when I move it. It never snaps properly to be centered. I have tried the Xray view to do this but am still struggling. Any suggestions? Thanks
You should be able to infer the center of the hole to the center of the axis. Another way would be the following. Move the wheel components’s axes so the origin is at the center of the hole for the axle. Drag an instance of the wheel component in from the Components panel and drop it on the end of the axle. Select the wheel and use the Flip tool to make the opposite side. Here’s an example. In this case, because the shaft the flywheel mounts on extends out beyond the hub, I identified that distance with crossing guidelines and set the component’s origin on that intersection. Since the model straddles the red axis I used that as the flipping plane. this is a video clip. Click on the picture.
FWIW, if you modeled the wheel and the spindle and the rest of the cannon in the same file, the easiest thing would be to model the wheel in place on the spindle rather than separately. I would like start a model like that from the axletrees and spindles and build the wheel component in place as well as the reset of the parts. The tractor model I used for my example started with the base plate and everything else was modeled in place and I just used Flip in cases where I have left and right copies.
