Is it possible to use Minitest::Spec::DLS to write TestUp tests?
most likely to @tt_su…
Yes, it’s possible with some diligence. It would probably have looked more prettily with the original reporter, and perhaps one day (which is unlikely) it would turn into a real gem. But it’s working now and if you’re a ‘believer’ in TDD and use tests to write code, I’ll be happy to share it with you.
module Parametric
module Tools
module BoxTool
module Tests
extend Spec::TestsRoot
describe BoxTool do
test_helpers Tools::Helpers
let(:transformation) { IDENTITY }
let(:view) { Sketchup.active_model.active_view }
let(:xyz_tool) { mock_tool(xyz_stage_result, transformation) }
let(:profile) { Parametric::Geom.rectangle ORIGIN, ::Geom::Vector3d.new(10,20,0) }
let(:push_pull_tool) { mock_tool(push_pull_stage_result, profile) }
let(:push_pull_stage_result) do
view: view,
vector: ::Geom::Vector3d.new(0, 0, 30)
end
let(:xyz_stage_result) do
view: view,
vertex: ORIGIN,
vectors: Geom.decompose_vector(ORIGIN.vector_to([10,20,30]))
end
before do
@truly_xyz = Tools.set_default(:xyz_tool, xyz_tool)
@truly_push_pull = Tools.set_default(:push_pull_tool, push_pull_tool)
end
after do
Tools.set_default(:xyz_tool, @truly_xyz)
Tools.set_default(:push_pull_tool, @truly_push_pull)
end
describe 'workflow' do
subject do
tn = transformation
tool_fixture(BoxTool) do
@transformation = tn
end
end
before do
subject.activate
end
context 'when first stage returns flat' do
vertex: ORIGIN,
vectors: [::Geom::Vector3d.new(10, 0, 0), ::Geom::Vector3d.new(0, 20, 0)]
end
it 'uses xyz_tool' do
expect(xyz_tool).must_be :used?
end
it 'uses push_pull_tool' do
expect(push_pull_tool).must_be :used?
end
end
context 'when first stage directly returns box' do
view: view,
vertex: ORIGIN,
end
end
it 'skips push_pull_tool' do
expect(push_pull_tool).must_be :unused?
end
end
end
describe '.as_stage' do
let(:done_flag) { Minitest::Mock.new.expect(:call, nil, [expected_callback_params]) }
subject do
Parametric::Tools::BoxTool.as_stage { |params| done_flag.call params }
end
let(:expected_callback_params) do
view: view,
position: transformation,
x: 10, y: 20, z: 30
end
it 'returns Stage instance' do
expect(subject).must_be_instance_of Parametric::Tools::BoxTool::Stage
end
it 'activation makes callback with expected params' do
subject.activate
done_flag.verify
end
end
end
end
end
end
end
FYI, it is required to choose and use a unique top-level namespace module that all your extensions will be wrapped within. The word “Parametric” is rather common. (I do understand if this is just an example to get TestUp working. Just saying, so newbs can get this idea in their heads.)
