Version 2.6.8 - 04.10.2020
- Fixed a show_modal bug for macOS in the Timber Truss HTML menu dialog.
With this latest release I’ve had to migrate to the .rbe encryption system so this version will no longer run on SketchUp 2015 or earlier.
Version 2.6.9 - 04.11.2020
There are still a number of truss types and rafter roofs that still need edit capabilities, I am slowly working through this list.
Version 2.7.0 - 04.12.2020
Version 2.7.1 - 04.13.2020
Skylights have not been on my official todo list but now they are.
I’ve actually been tossing the Skylight idea around for a while now, how best to implement it within the various roof modules. I’ve got some ideas already but I haven’t finalized it yet.
Does anyone have any specifics or suggestions on the actual skylight models/components that I should use. Specific brands, reference drawings, that sort of thing.
My thinking is to have some fairly generic skylight models that the user could chose from. The skylight module would then bring these components into the model and also cut the corresponding holes in the roof cladding and sheathing. I would also have a tool for editing and deleting a skylight. As far as moving the skylight on the roof plane, I would allow the user to simply click into the roof assembly and moving the skylight with the native tools as they see fit, this would be the simplest way of handling re-positioning.
Again, I’m still tossing this idea around, trying to shake out the best system for implementing it, any feedback is appreciated.
Inserting a skylight into a roof is almost the same as inserting a window into a wall, except there aren’t jack studs, just typically doubled rafters, and joist hangers for the header. These days, I only really use Velux. I do like them myself. There are 6 in my own house.
Sun Tunnels (all brands including Velux) would be my suggestion. A favorite amongst interior designers. Natural light can be incorporated into home design with ease.
http://www.veluxusa.com/products/sun-tunnels
An interesting article:
Velux seems to be the predominate choice for skylights.
Now I just need some low poly, dimensionally accurate models for this module:
Above is a cross section of a curb mounted Velux VCM skylight.
All of the actual skylight hardware detail is irrelevant, the curb geometry (2x4s) needs to be accurate and the glass and over all model for the skylight should be as low poly as possible but when rendered should look fairly realistic.
Here’s their table of sizes and code number system:
Velux has their official models in the warehouse but as usual there are too many details in these models, so I had to create my own low poly versions that are dimensionally accurate:
First look at the Skylights Toolbar:
Version 2.7.2 - 04.24.2020
I still need to enable editing and labels for tail bearing trusses.
Version 2.7.2b - 04.24.2020
This update also resolves a potential bug that could cause the plugin to go into a infinite loop if the birdsmouth cut exceeds the depth of the top chord of the truss. If you are using tail bearing trusses I highly recommend upgrading to this latest release.
The updated module is now properly creating the gypsum on the underside of the truss (three pieces).
Version 2.7.4 - 05.02.2020
This bug fix is specifically for the boxed soffit for truss roofs. Previously if one did not enable the fascia but enabled the soffit then it would throw an error. There may be other similar bugs in this module or others so I am constantly testing combinations of various parameters to make sure no interdependencies have been overlooked.
Version 2.7.5 - 05.05.2020
This small adjustment of the Trim tool is to bring it inline with the Trim 2 tool. This feature is per customer request.
First look at the skylight tool in action:
Note, that this image shows the skylights added to a generic roof. For the cutouts to work the roof geometry must be a valid solid group or component within an overall assembly group for the roof or building.
Initially there are three skylights (sizes) to choose from however it is possible to add your own skylights into the library.
The cut function can be toggled on/off in order to cut through the sheathing and cladding or in this case just a generic roof solid.
At some point I would also like to add in a few VELUX Sun Tunnels.
Now I just need to figure out how to heal the roof when a skylight is deleted or edited. For a Medeek roof that is fairly straight forward, just regen the roof, however for a generic solid things get a little more tricky.
Version 2.7.6 - 05.11.2020
I also added an additional tool for “regenerating” the skylights, this comes in handy after modifying the location of a skylight or if a Medeek roof gets regenerated and the holes in the sheathing and cladding need to be re-cut.
There are few new global settings I still need to add to fully complete this new module but overall it seems to be working quite nicely.
View model here:
The same logic I am employing for the skylights as applied to generic roofs can now also be used for the window and door modules so that they can work with generic walls.
