Hi Im a bit of a newb, can you tell me why the brickwork on the left is why it is, no matter what angle I view it, its the same patchiness
Thansk
Tess
What you are showing is known as Z-fighting. It occurs when two faces are so close together that the graphics card can’t decide which one should be in front of the other. Remove or hide one face and the problem will go away.
Before you start applying textures to your model correct the face orientation. Most of the faces shown in your screenshot are reversed. There should be no exposed blue back faces in your model.
By the way, please correct your profile. It says you are using SketchUp Free (web) 2018 which isn’t possible and your screenshot shows you are using SketchUp Pro 2021. Also put in the model of the graphics card. “66” doesn’t identify it.
Thanks Dave, Can you tell me how to alter my profile info
Click on the T in the pink circle in the upper right corner of the forum page. Then click on the person icon followed by the gear icon. You should see the options to edit your profile there.
