Making a cutting component dynamic
hi,
I’m trying to make a cut out in a corner of an object with a thickness
futher I’m trying to make this cut out dynamic so I can resize it when needed.
does anyone have any suggestions?
below a picture of the end result I’m trying to achieve
You will need to make 3 sub groups or sub components with hidden edges and deleted interior faces.
The size of the blue and orange rectangular prism correspond to the w and l and your cut. The remaining shape is what is left over. You will need to work with formulas to create and position the shapes.
this might be the easiest way. I can make this work, thanks for the quick reply!
AFAIK there is no other way, easy or not.
