Line and distance between selected cpoints
Hello,
I’m looking for a part of code that draws a line between selected cpoints and get the distance.
To get the selected cpoints you can use:
m=Sketchup.active_model; s=m.selection; s.grep(Sketchup::ConstructionPoint);
but how can you transfer the collected points to usable points to create lines or get the distance between it?
Thanks
Let’s assume:
cpts=s.grep(Sketchup::ConstructionPoint)
Then:
cpts.each{|cpt|
  ### do something with each cpt here
E.G. to find the position of each ‘cpoint’ use:
pt=cpt.position
This is a ‘point3d’ object.
If you want to draw a line to another point, use:
edg=m.active_entities.add_line(pt, some_other_point)
To find the distance from the pt to some_other_point, use:
dis=pt.distance(some_other_point)
Thanks again Tig,
I only get the following error:
undefined local variable or method ‘some_other_point’ for #<AS_RubyEditor::RubyEditor:0x000000078d3cc0
when i do this:
m=Sketchup.active_model; s=m.selection; cpts=s.grep(Sketchup::ConstructionPoint)
cpts.each{|cpt|
 pt=cpt.position
Where and when did you define some_other_point? It either doesn’t exist at all, or is in a namespace that isn’t visible inside the each block.
The clue is in the error message !
If you don’t define ‘some_other_point’ as a point3d or a three element array, then it is going to fail !!
Please read what you type, and what error messages you get back.
I only used ‘some_other_point’ as a ‘placeholder’ in the code example - you need to expend at least a little effort to get it to work like you want it to…
A thanks sorry and i see the glue now :slight_smile: i was i little bit to fast
