Is there a way to do “File > Export > Images” with the ruby api?
I checked the api but don’t seem to find it.
I don’t think so. When PDF exports have been discussed in the past the answer has been to manually rebuild it using a PDF library and exploding viewports to get out the images and lines.
use view.write_image
options = {
:filename => "c:/tmp/write_image.png",
:width => 640,
:height => 480,
:antialias => false,
:compression => 0.9,
:transparent => true
model = Sketchup.active_model
view = model.active_view
view.write_image(options)
Shoot, I missed the layout
tag.
You can write to image in layout as well:
(give me a second)
EDIT:
… but not from ruby it seems
You can however export images using the c sdk
result = LODocumentExportToImageSet(document,
output_path.c_str(),
output_name.c_str(),
image_format,
options_dict);
Thanks for the answers.
I knew it is possible with the c sdk option, but for now I just manage to do the ruby solutions…
When i have the time, i will have to look for some getting started thing i guess.
Let me know if you need help with that.
