Hi , trying out Layout 2019 before buying and i noticed certain default trays don’t collapse, and when i change the line scale in the Sketchup model tray the entire Default Tray becomes unusable. Cant click on anything
Which trays don’t collapse?
Did you install SketchUp and LayOut correctly? That is, did you right click on the downloaded installer and choose Run as administrator from the context menu?
As for the line scale setting. Are you waiting for the viewport to re-render? Try it with a simple model and see if you get the same result.
