Hello,
I’m developing a plugin that uses UI.inputbox with dropdown lists.
My parameters are stored in a dictionary.
The problem is that each time I display the dialog box, I get 5 “Properties” entries in the undo stack.
I was able to isolate the problem with this 2 minimal codes :
# Test with dictionary
def test_with_dict
model = Sketchup.active_model
dict = model.attribute_dictionary("Test", true)
dict['val1'] = "Yes"
dict['val2'] = "No"
prompts = ["Option 1:", "Option 2:"]
defaults = [dict['val1'], dict['val2']]
list = ["Yes|No", "Yes|No"]
result = UI.inputbox(prompts, defaults, list, "Test with dictionary")
end
test_with_dict
When running in the Ruby console, this code produce 3 entries in the undo stack.
# Test without dictionary
def test_without_dict
defaults = ["Yes", "No"]
result = UI.inputbox(prompts, defaults, list, "Test without dictionary")
end
test_without_dict
0 entries in the undo stack.
I tried extracting the values from the dictionary into local variables before calling inputbox but it doesn’t work.
Is there a solution to avoid these multiple entries in the undo stack?
Thanks in advance for your help.
