I have created a quick Ruby program to draw quarter-elliptical faces, some at a slant, to make a quarter of a large arch, structural columns and elevator shafts.
I have set up an array of defaults, but of the seven input fields, only five are being set initially to the specified defaults.
Inputs 3 and 4 just repeat defaults 0 and 1.
Here are what I think are relevant fragments of the code:
def initialize
@defaults = [930.75.feet, 875.5.feet, 0.0, 917.9167.feet, 862.6667.feet, 0.0, 0.feet, "OTR elev", "No" ]
end
def get_inputs()
## Get user input parameters for arch section#######################
defaults = @defaults
prompts = ["Major semi-axis 1 ", "Minor semi-axis 1 ", "Slope 1 (between -1 and +1) ",
"Major semi-axis 2 ", "Minor semi-axis 2 ", "Slope 2 (between -1 and +1) ",
"y_offset", "Name", "Add floor numbers?"]
list = ["930'9|929'9|928'5|918'5|917'11","875'6|874'6|873'2|863'6|862'8","0.0","930'9|929'9|928'5|918'5|917'11","875'6|874'6|873'2|863'6|862'8","0.0","0|10'2","","No|Yes"]
input = UI.inputbox(prompts, defaults, list, "Arch section parameters" )
if defaults.nil? || defaults.empty? # not previously defined defaults or input
if !input.empty?
# remember inputs ready to adapt for next section of arch
@defaults = input
end
end
if input
a1 = input[0].to_l
b1 = input[1].to_l
slope1 = input[2].to_f
a2 = input[3].to_l
b2 = input[4].to_l
slope2 = input[5].to_f
y_offset = input[6].to_l
component_name = input[7]
show_floor_numbers = input[8] == "No"? false : true
if slope1.abs >1 || slope2.abs >1
UI.messagebox "Slope must be between -1 and +1. Please try again", MB_OK
end
if b1 > a1 || b2 > a2
UI.messagebox "Major axis must be larger than or equal to minor axis", MB_OK
end
else
UI.messagebox "Sorry, invalid values, please try again", MB_OK
end
@defaults = input
What I get when I run this is:
Inputs Major and minor semi-axis 2 should be showing defaults of 917.9167.feet, 862.6667.feet, (that’s 917ft 11in, 862ft 8in) but are showing the same as semi-axes 1. When I pick the correct values in the drop down lists, they work correctly. It’s just the default isn’t selected.
Is it just because the decimal representation isn’t being recognized as the same as the list value, which is in ft and in? So what is showing (I’ve just realised) is the first value in each of the drop-down lists, which are the same for a1 and a2, and also for b1 and b2.
Is there a way round that? Could I use a literal string in the @defaults array and have it interpreted as a length?
It isn’t a show stopper, but I have to run the code multiple times, and it’s a pain to have to reset the starting values every time.
