Issue related to units
when I use a very big number as in thousand the script does not provide any output. however, when i use a small number like 5 or 10 the script work very well.
if you have any clue related to this issue, please help me fix it.
Regards
It’s not possible to answer without a sample of code that has the issue. Is this related to your other topic?
yes its related to other topic.
i tired the same script with small number. its working well, but when i use the real number as in thousand i have no result.
SketchUp internally uses inches. And all coordinates are limited to a precision of 0.001".
And two points closer than one thousandth of an inch, will be converted to a coincident vertex.
So there’s not much sense in using those crazy numbers with the minute decimal fractions down to the width of a molecule. :roll_eyes:
What script?
your issue is with ‘distance’ not ‘units’,
why do you want to move entities 500 km [approx]…
an overview of what you are actually trying to achieve should be added in the original thread…
john
Yes right with distance the issue. when i use such far far distance i experience this issue, im trying to built a 3D model for a downstream area of a dam so that i extract this distances from GIS. its scaled and need to be in that location to be fit with the other objects.
