# code here
def collect_vertices(container, cumulative_transformation = Geom::Transformation.new)
vertices = []
entities_to_process = [[container, cumulative_transformation]]
while !entities_to_process.empty?
current_container, current_transformation = entities_to_process.pop
# Skip if the object is hidden
next unless current_container.visible?
# If it is a ComponentInstance, convert it to its ComponentDefinition
if current_container.is_a?(Sketchup::ComponentInstance)
current_container = current_container.definition
end
# If it is a ComponentDefinition or Group, collect the vertices
if current_container.is_a?(Sketchup::ComponentDefinition) || current_container.is_a?(Sketchup::Group)
# Filter all Edges (skip hidden edges)
edges = current_container.entities.grep(Sketchup::Edge).select(&:visible?)
# Collect vertices from each Edge
edges.each do |edge|
edge.vertices.each do |vertex|
vertices << vertex.position.transform(current_transformation)
end
end
# Filter Groups and ComponentInstances (skip hidden objects)
groups_and_instances = current_container.entities.grep(Sketchup::Group).select(&:visible?) +
current_container.entities.grep(Sketchup::ComponentInstance).select(&:visible?)
# Add Groups and ComponentInstances to the processing list
groups_and_instances.each do |entity|
new_ct = current_transformation * entity.transformation
entities_to_process << [entity, new_ct]
end
end
end
vertices
end
Post code correctly in the forum and please edit your previous post.
thank you, i have read the article, i will make adjustments to my source code
