Is there a function to know a group or a component is a solid group or a solid component?
Hi Experts,
A Solid in SketchUp is a single Group or Component whose geometry meets certain conditions. When those conditions are met, Entity Info in SketchUp application indicates the model is a Solid Group or Solid Component.
In SketchUp SDK, is there a function to know a group or a component is a solid group or a solid component? Or Is there a function, its input is faces, then output is to tell you if these faces can be converted as a solid or not?
Thanks
Phenix
Hi Experts,
In SKP SDK, there are two functions “SUComponentDefinitionOrientFacesConsistently()” and “SUModelOrientFacesConsistently” which can fix the face orientation issue. Could you please give more comments about their differences?
Thanks
Phenix
In ruby the function is group.manifold?
It returns true if the group is a solid.
how about C?
In a roundabout way yes.
Firstly, groups would need to be cast to a ComponentInstance using …
SUGroupToComponentInstance
Secondly you would attempt to get the volume of the instance using …
SUComponentInstanceComputeVolume, and test the result for not SU_ERROR_NO_DATA
(which is returned if the instance is not manifold.)
Enhancement Issue logged:
