Import pdf drawing to layout
Hi All
Is it possible to import a pdf file of a landscape drawing to Sketchup layout?
I am a landscaper and Garden designer, but recently been asked to modify a landscape drawing of a housing development. The drawing is fully rendered as a pdf. The current pdf drawing is not complete in that it just shows planting areas. I need to detail the plants in each area if this makes sense! To do this would just require adding text/arrows to the drawing.
What is the best/easiest way to get a pdf plan to layout?
Thanks for your help
Many thanks
Jason Sutton
All Seasons landscapes
Cranham.park.pdf (2.2 MB)
Wouldn’t this be great to have?
Depends on the PDF. On Windows there’s no direct option to import PDF files but you can generate a PNG or JPG image from it which can be imported. If the drawing in the PDF is vector linework you could generate a .dxf file from it using Inkscape or other tools. Then import the .dxf file into Sketchup or inserted into LayOut.
Thanks for the reply Dave.
How can i tell if the drawing is vector linework? The pdf will have come from a cad drawing.
I would like ti keep the plan as it is and just add some text.
Where will i find non direct pdf import if i need this.
I had tried inkscape…i entered file in the app but it wouldn’t load up…(nothing happed lol) so just assumed it wasnt working
Here’s an example from a randomly selected PDF I downloaded.
I opened the PDF in LibreOffice, right clicked on the image and selected Save.
Then I inserted the image into LayOut.
Ready for labels and whatever else needs adding.
I guess look at the line work to see if it’s raster or not.
If you need to create a PNG or JPG to insert you can take a screenshot with the Snipping tool or other screen shot apps. Or you can try when I showed in my previous post.
Hmmm… How did you try opening it?
