I have a face and I want to transform the face so that the face normal is aligned with start vertex for another edge using ruby .
Should work if you create a transformation like this:
Assuming the face is drawn on the ground plane (z = 0)
origin = edge.start.position
axis = origin.vector_to(edge.end.position)
trans = Geom::Transformation.new(origin, axis)
entities.transform_entities(trans, [face])
I haven’t tested this but it will hopefully get you on the right track!
this doesnt work. it will move only the face in the direction of the vector.
