Direction axis
Hello everyone,
how to get direction axis perpendicular to the selected face with the click of the mouse, through the ruby language, a help to show me the way to follow or the part of the manual to watch and study or some example to follow and study.
thanks
Joseph
face.normal
Note that if the face is not within the general model’s entities but is within a group or component-instance then you need to get its transformation and apply that to the normal’s vector value to compensate for the fact the container might be rotated etc…
I’m extending the code snippet given by me in your other topic.
Reference links (see in code comments)
(1) Face#normal-instance_method
(2) Vector3d#axes-instance_method
(3) Axes#set-instance_method
(4) top-level-namespace
class TesttoolAxes
  def initialize
    @face = nil
    @tr = IDENTITY
  end
  def deactivate(view)
     # restore the original axes when the tool deactivated /link (3) & (4)/
     # the result is same as the user right click one of the axis
     #  and choose "Reset" from context menu
    Sketchup.active_model.axes.set(ORIGIN, X_AXIS, Y_AXIS, Z_AXIS)
  end
  def get_trans(ph, obj)
    ph.count.times{|i|
      if ph.leaf_at(i) == obj
        return ph.transformation_at(i)
      end
    IDENTITY
  end
  def onMouseMove(flags, x, y, view)
    ph_fe = view.pick_helper
    ph_fe.do_pick(x, y, 0)
    face = ph_fe.picked_face
    @face = face ? face : nil
    @tr = get_trans( ph_fe, face ) if face
    view.invalidate
  end
  def onLButtonUp(flags, x, y, view)
    if @face
      @c_face = @face
      @c_tr = @tr
      puts "#{@c_face} outer loop is highlighted."
      # get new z-axis from the face normal /link (1)/
      # considering it's parent's transformation
      # this is perpendicular to face
      new_zaxis = @face.normal.transform( @tr )
      # compute an arbitrary set of axes with the given vector
      #   as the z-axis direction  /link (2)/
      new_xaxis = new_zaxis.axes[0]
      new_yaxis = new_zaxis.axes[1]
      # set the axes with the new vectors / link (3)/
      # in this example I keep the origin, but
      # the first parameter can be other (Geom::Point3d)
      Sketchup.active_model.axes.set(ORIGIN, new_xaxis, new_yaxis, new_zaxis)
    end
    view.invalidate
  end
  def draw(view)
    if @face
      loop = @face.outer_loop.vertices.map{|v|
        v.position.transform( @tr )
      view.drawing_color = [0,0,256, 64]
      view.draw(GL_POLYGON, loop)
      view.drawing_color = [0,0,256, 32]
      view.draw2d(GL_POLYGON, loop.map{|p| view.screen_coords(p)})
    end
    if @c_face
      c_loop = @c_face.outer_loop.vertices.map{|v|
        v.position.transform( @c_tr )
      view.line_width = 3
      view.drawing_color ="blue"
      view.draw(GL_LINE_LOOP, c_loop)
    end
  end
end
Sketchup.active_model.select_tool(TesttoolAxes.new)
EDIT:
In case you want to go back as it was before the tool activated, 2 methods will looks like
  def initialize
    @face = nil
    @tr = IDENTITY
    @orig_origin, @orig_xaxis, @orig_yaxis, @orig_zaxis = Sketchup.active_model.axes.to_a
  end
     # restore the original axes as before the tool were activated
     # when the tool deactivated
    Sketchup.active_model.axes.set(@orig_origin, @orig_xaxis, @orig_yaxis, @orig_zaxis)
  end
…and: Sketchup.active_model.axes.set(ORIGIN, new_xaxis, new_yaxis, new_zaxis)
    Sketchup.active_model.axes.set(@orig_origin, new_xaxis, new_yaxis, new_zaxis)
  end
typo in the last line: @orig_xaxis is repeated where y and z should be.
Thank you very much for sending me these lines of code… now I study it… good evening.
Joseph
Thank you very much…
good evening.
Joseph
