Hi i m in need of a little help,i need to draw a rectangle (32mm x 22mm) with radius corners (hollow if poss) then stretch it and turn it into a circle (radius 32mm hollow) maybe around 50mm long how do i do this ?
Could you show an example of what it is you’re actually trying to do? Why do you have to do this with Push/Pull? What do you mean by [quote=“nutcase, post:1, topic:18785”]
[/quote]?
This has been covered a number of times recently. Here’s a link to a thread that should help.
Once you have mastered the manual method you can start looking at plugins.
thanks thats amazing, i dont suppose you know how to cut the finished item in half and flatten it so i have a template? lol
something like this?
sort of cotty but the first video was spot on but thanks
What is the name of that plugin for the morph?
@Box used Fredo6’s Curviloft extension, which is available free from the sketchUcation plugin store (note: it depends on libFredo6, which must also be installed).
