I am doing code like this…
def material_name comp
ents=comp[0].definition.entities
ents.each do |e|
if e.is_a? (Sketchup::ComponentInstance)
puts e.material.map{|x| x.name}
end
end
end
material_name Sketchup.active_model.selection
ents.each do |e|
end
end
end
You need to write the code inside of triple backticks for it to be readable.
Code goes here…
To change the name of an instance’s material’s nam you can do something like this:
instance.material.name = "New Name"
thank you
When a method definition (def) does not work, try to decompose it and run it in tiny small steps:
comp = Sketchup.active_model.selection
e = ents[0]e = ents.find{ |entity| if entity.is_a?(Sketchup::ComponentInstance) }puts e.material.map{|x| x.name}
puts e.material
