How to set_attribute to a line
Hi,
Is it possible to set an attribute to a line? (No its not - but??)
#this don't work
my_line.set_attribute "dict", "key", "value"
Because I need to be able to search the model for specific lines to get the length of those lines.
Is there any other workarounds to solve that problem?
Edges, as well as all other Entities, can have attributes: Class: Sketchup::Entity — SketchUp Ruby API Documentation
Id the variable my_line referring to an Edge or the mathematical concept of a line?
are you sure?
line_with_attr = @component_def.entities.add_edges edge_pts
# line_with_attr have no set_attribute method
puts	line_with_attr.methods
In my case it dont have a set_attribute method. I use SU2016
add_edges returns an Array of Edge objects, not an Edge object.
You can divide your code into smaller steps and output the results in the console to know what objects types you are working with.
wow yes - now it works!
line_with_attr.each_with_index do |myline,g|
  # working
  myline.set_attribute "rsdict", "yv_line_length", 0.00
end
thank you very much!
