How create an attribute for guidepoint?
#1
How could I create an attribute? for an array coordinates. This attribute could be a color or whatever helps me know one of them is different from the rest. Hey image
All guidepoints must have same color (or a Boolean attribute; It just have to work) but one of then I’ll choose manually.
require "yaml"
def cnc()
	model = Sketchup.active_model
	ents  = model.entities
	view  = model.active_view
	faces = ents.grep(Sketchup::Face)
	faces.each {|face|
		loop = face.outer_loop
		edgeuses = loop.edgeuses
		pts = []
		edgeuses.each {|use| pts << use.edge.start.position.to_a}
		until pts[0][1] == face.bounds.min[1]
		  pts.rotate!
		end
		pts.each {|pt| ents.add_cpoint(pt)
		#sleep 0.5
		#view.refresh
end
def cnc_menu()
    tools_menu = UI.menu("Tools")
    tools_menu.add_separator
offest_all_faces_item = tools_menu.add_item("CNC New Project") {
cnc()
end
cnc_menu()
#2
Please post code correctly in the forum:
You can identify Sketchup::Drawingelement subclasses by checking and saving a persistent ID between sessions …
Any entity subclass object can have an attribute dictionary created for it …
# At top of Plugin Module
DICT = "YourCompanyName_YourPluginName"
# some where in the code
def add_attr( obj, key, value )
  obj.set_attribute( DICT, key, value )
end
# Elsewhere calling the method using a ConstructionPoint reference ...
add_attr( cpoint, "Position", cpoint.position )
add_attr( cpoint, "Type", "Start" )
#3
This is my code again but it didn’t work for me
require "yaml"
require "sketchup.rb"
#require "extensions.rb"
DICT = "havanaapplegod_cncnew"
def cnc()
	faces.each {|face|
		pts = []
			#add_attr( pts[0], "Type", "Start" )
		print "PTS =", pts
		  pts.rotate!
		end
			add_attr( ents,  "Type", "Start" )
		#sleep 0.5
		#view.refresh
end
end
def cnc_menu()
    offest_all_faces_item = tools_menu.add_item("CNC New Mother Fucker") {
        cnc()
end
cnc_menu()
]Error: #<NoMethodError: undefined method `set_attribute' for #<Sketchup::Entities:0x007fa5cff7e3e8>>
/Users/joemac/Library/Application Support/SketchUp 2018/SketchUp/Plugins/CNCNew/cncnew.rb:51:in `add_attr'
/Users/joemac/Library/Application Support/SketchUp 2018/SketchUp/Plugins/CNCNew/cncnew.rb:41:in `block (2 levels) in cnc'
/Users/joemac/Library/Application Support/SketchUp 2018/SketchUp/Plugins/CNCNew/cncnew.rb:40:in `each'
/Users/joemac/Library/Application Support/SketchUp 2018/SketchUp/Plugins/CNCNew/cncnew.rb:40:in `block in cnc'
/Users/joemac/Library/Application Support/SketchUp 2018/SketchUp/Plugins/CNCNew/cncnew.rb:20:in `each'
/Users/joemac/Library/Application Support/SketchUp 2018/SketchUp/Plugins/CNCNew/cncnew.rb:20:in `cnc'
/Users/joemac/Library/Application Support/SketchUp 2018/SketchUp/Plugins/CNCNew/cncnew.rb:62:in `block in cnc_menu'
SketchUp:1:in `call'
#4
After reading the error message, you verify it by looking up the API documentation and not finding Sketchup::Entities#set_attribute. So either another method should have been called, or that method should have been called on a single entity.
#5
You are trying to add the attribute to the entities collection, I think you want to add it to a cpoint.
Try this code change:
pts.each{|pt|
  cpt = ents.add_cpoint(pt)
  add_attr( cpt,  "Type", "Start" )
Although I don’t see where you use it later anyway ??
#6
How can I access to cpoint attributes?
I list all entities on my model but I can’t see those points listed.
ents.each{| ent | print “\n ent : “, ent
#7
You can make it simpler, but this explains the steps…
Note that using
ents = model.active_entities
to work in all contexts, not just the base
model.entities
First:
cps = ents.grep(Sketchup::ConstructionPoint)
# array of all cpoints
Now process that array to find just those cpoints with the matching attribute.
starts = cps.find_all{|cp| cp.get_attribute(DICT, 'Type', '???') == 'Start' }
# where 'starts' is an array of any of those cpoints
# that have their 'Type' set to 'Start'
#8
… also it doesn’t make much sense to assign all of the cpoints as the start. There is usually 1 start, 1 end, and intervening points along the arc.
#9
Update 0.8 check this out
require "yaml"
def cnc()
	faces.each {|face|
		pts = []
		print "PTS =", pts
		  pts.rotate!
		end
		ptfirst = 0
			if ptfirst == 0
				add_attr( cpt,  "Type", true )
			else
		  		add_attr( cpt,  "Type", false )
			end
			#sleep 0.5
			#view.refresh
			print "\nptfirst ==", ptfirst
			ptfirst += 1
		# Check the Attribute
		starts = cps.find_all{|cp| cp.get_attribute(DICT, 'Type', '???') == true }
		starts.each {|attr|
			print "\n The Attribute ==", attr
end
end
def cnc_menu()
    offest_all_faces_item = tools_menu.add_item("CNC New BETA 0.7") {
        cnc()
end
cnc_menu()
———— Console Output ——
PTS =[[27.183060952514595, 22.17309422937775, 0.0], [27.183060952514595, 29.662646004791227, 0.0], [36.49626760787338, 29.662646004791227, 0.0], [36.49626760787338, 44.62585013488956, 0.0], [49.63581685802641, 44.62585013488956, 0.0], [49.63581685802641, 22.17309422937775, 0.0]]
ptfirst ==0
ptfirst ==1
ptfirst ==2
ptfirst ==3
ptfirst ==4
ptfirst ==5
 The Attribute ==#<Sketchup::ConstructionPoint:0x007fb9c0e86d00>
It seems to be working property but clarify if I’m wrong; I do this listing
starts.each {|attr|  print "\n The Attribute ==", attr }
Then I got this result; is 0x007fb9c0e86d00 a memory pointer? Or encrypted property? anyway how can I get the value inside the attribute.
#10
Use the get_attribute() method.
#11
Please note that in your code:
When you printing out you are printing the ConstructionPoint itself with his unique ID.
To get the attribute you have to ‘ask’ it:
starts.each {|cpoint|
  attr = cpoint.get_attribute(DICT, 'Type', '???')
