How to scale an object (Green Scale about Opposite Point)
Hello, I’m trying to scale an object which I do manually with Scale tool on a specific point, dragging from Green Scale about Opposite Point, like on the screen:
And dragging from Green Scale about Center, when pressing ‘CTRL’:
I didn’t found in documentation how to scale from that points, but I found this point:
I drew a line between that point and the center of object, and this is the point where “Green Scale about Opposite Point” is situated, I named it in code ‘point_to_scale’.
So I tried to use this method but the result is not what I expected:
  value_to_scale = 1.1
  scale_transform = Geom::Transformation.scaling(point_to_scale, value_to_scale)
  instance.transformation *= scale_transform
Could you help me with an advice how it can be done like with scale tool from SketchUp?
Thank you.
When scaling it by 1.1 it makes it 1.1x bigger [in XY&Z].
To ‘flip’ use -1 in the required axial direction.
I appreciate we can’t see all of your code, but a scaling transformation can take various arguments.
So I’m unsure which is which axis of the object - I’ll assume ‘Y’ is the ‘green’ scale your refer to…
In your case perhaps:
cpt = instance.bounds.center
scale = Geom::Transformation.scaling(cpt, 1, -1, 1)
instance.transform!(scale)
See this API page… Class: Geom::Transformation — SketchUp Ruby API Documentation
Thank you for your reply, based on your code, I found solution for my needs.
instance_bb = instance.bounds
tr=instance.transformation
center = instance_bb.center
ip=tr.origin
if is_oriented_on_x
   point_to_scale = [ip.x, center.y, center.z] #for scale about opposite point
   #Green Scale about Opposite Point
   scale = Geom::Transformation.scaling(point_to_scale, value_to_scale, 1, 1)
   #Green scale about Center
   #scale = Geom::Transformation.scaling(center, value_to_scale, 1, 1)
 else
   point_to_scale = [center.x, ip.y, center.z] #for scale about opposite point
   #scale = Geom::Transformation.scaling(center, 1, value_to_scale, 1)
   #Green scale about Opposite Point
   scale = Geom::Transformation.scaling(point_to_scale, 1, value_to_scale, 1)
 end
